Two step people????????
the yellow wire is coiled up neatly under hood for when I graduate college in 8 months and I can spray it cause i will have a new car. so that only leaves two wires. the cruse control wire (pretty sure that will not help me)
and the button wire,,,,, that is easy for me to get to too
so how can I use the activation button to also turn on a light or LED when it is still on.
I want this cause I puller up to the line tured it on then had to move a little on the gate, thought it turned it letting out on the clutch buit did not so when I turned it "back on" I thought I really turned it back off for real. then floored it and no two step just rev limiter. so any help would be great..
sorry for long post
Tie the positive side of the LED to 12V, the negative side to the yellow wire on the 2 step.
LED on, 2 step armed/active. LED off, no 2 step.
Simple
If you're using the latch mode on the 2 step, it may not matter if you have the button pressed.Running a light off the "active" (ie yellow) wire on the 2 step won't impact using it for nitrous disable in the future.
That's why I put it in the box in the first place
that sux haha
all my wires are all wraped nice and trhe yellow one is not with them haha that why I wanted to use it. the butin wire is allready in the cockpit.
so how does the yellow wire work for N2O if you don'tmind
splice the relay into your activation circuit for the nitrous using terminals 30 and 87a.
that's it.
that sux haha
