Drag Racing Tech
ls1 2 step
Old Sep 8, 2005 | 10:40 PM
fotoboy's Avatar
Default ls1 2 step
IS it possible to run a 2 step on a C5 m6? Or some thing else that would allow me to hold it to the floor at a desired RPM
What are you guys launching your M6 at the drag with dr?
Have heard of guys pegging the rev limiter and side stepping the clutch! This seems a little extreme to me cosidering if you are running a auto its a lot lower.
Old Sep 8, 2005 | 10:49 PM
liftin'em on nittos's Avatar
there are a couple 2steps available for the LS1 cars that i know of. Harlan makes (not sure he still does) one for the fbodies that lots of guys use. i'll be using one myself!! good luck
Old Sep 8, 2005 | 11:02 PM
LC's Avatar
LC
sorry...
i tried to search but nothing came up on what IS a 2step.. or how it works..
can someone explain please...
Old Sep 9, 2005 | 12:38 PM
z-ya's Avatar
Ive got harlans 2 step and it works perfect,don't know of any other one for ls1's.
It will hold any rpm you tell it to when it is active,then it goes off your revlimiter
when deactivated.I have mine latched off the clutch switch for the cruise control to
be activated when the clutch is depressed.I set mine to be active with the clutch
depressed and it goes inactive as soon as I release the clutch.This allows a consistent
rpm while staged without trying to watch the tach and tree at the same time.
