newbie at track
If you have slicks, then some tracks want a drive shaft loop. If the slicks are mounted on a rim which doesn't allow the stud to come all the way through, then you may need to find a rim that will work, or put longer studs in.
You could always just run the car in stock form, like the way you would arrive at the track and ask lots of questions and learn from those around you. Ask lots of questions. It's the only way to learn. Most guys are pretty good at revealing info.
