Drag Racing Tech
Do I shift into 3rd or 4th in 1/4 mile????
Old Sep 15, 2005 | 10:37 PM
Denom's Avatar
Default Do I shift into 3rd or 4th in 1/4 mile????
Well I had my car tuned to redline at 6600 rpms, but I don't know if I should be shifting into 4th 1/4 mile wise, as it takes up time, and I don't know if it is really necessary. My car is a M6. Any help would be appreciated.
P.S. what should I be trapping at (Track is at 1300 ft. above sea level)?
Old Sep 16, 2005 | 12:00 PM
Camaroholic's Avatar
It really depends on your rear gear and tire size. Stock 3.42's, stock tires, 3rd is probably fine. (good for around 110 mph). Shift to 4th would put you lower in the powerband and take time, like you said, so probably not worth it.
http://www.f-body.org/gears - a calculator you can use to estimate where things happen.
Step up to a 12-bolt with 4.10's (or 4.56's ), go with a 28" tire, and you'll need that 4th gear.
Old Sep 16, 2005 | 12:01 PM
Steve Burger's Avatar
LS1TECH Sponsor
What gear do you have?
Old Sep 17, 2005 | 07:14 AM
Denom's Avatar
I have the stock 3.42's. I don't want to invest in gears, unless I put in a Moser 12 bolt.
Thanks for the help guys
Old Sep 17, 2005 | 10:57 AM
revlimiter's Avatar
You should be getting into 4th, i do in my z06 with 3.42's
Old Sep 17, 2005 | 11:24 AM
BlueSix's Avatar
Your Z06 also has shorter 1st, 2nd, and 3rd gears.
Old Sep 17, 2005 | 01:40 PM
Denom's Avatar
Yeah the gearing is different in the Z06. Someone told me it's more like a 3.92 gear ratio.
Old Sep 18, 2005 | 01:27 AM
andypdbz's Avatar
i have stock gears and stock tires, every time i race i usually end up having to shift into 4th for less than a second, i tried to stay in 3rd but i hit the rev limiter just before i finished the 1/4 mile. so should i practice staying in 3rd or keep it at 4th?
Old Sep 18, 2005 | 04:29 PM
BlueSix's Avatar
With a stock car you need to shift into 4th.
Old Sep 18, 2005 | 11:02 PM
rtr2001ss's Avatar
5500 in 3rd is about 93 mph on stock 3.42. Just my .02
Old Sep 19, 2005 | 12:49 AM
BlueSix's Avatar
FYI you should be good to right around 115 in 3rd with the 6600 limit.
Old Sep 19, 2005 | 08:39 PM
98nosz28's Avatar
I trap at 116mph in 3rd gear, reving about 6800rpm, with 3.42s.
Old Sep 19, 2005 | 11:01 PM
SUX2BU's Avatar
stock rev limiter, gears and tires i hit 108 in the 1/4 in third gear.
Old Sep 27, 2005 | 11:23 AM
NateLS1's Avatar
same here. I bumped my limiter to 6500 so I could stay in 3rd. I did try shifting to 4th, seeing as my car doesnt make any more power after 6000 rpms and I only lost a 1/10. I still hit 108 tho
