what size rear spring
specs are
3000lb
strange single adjustable up front with 2.5 x 14 275lb
strange double adjustable in the back
bmr extreme duty drag rear sway bar
bme extreme duty torque arm
thanks in advance
Adjustable Spring Seat
I've talked to AFCO, Wolfe and a couple other companes about spring rates using the 10" coil-overs. 150# is close to stock and I'm running a little bigger than that. Should complement the AFCOs and loose spring up front.
I also have Wolfe's adj. perches. I would've had them in the car this weekend, but the plasma cutter took a ****.
