Drag Racing Tech
why shut of traction control?
Old Sep 27, 2005 | 06:38 PM
pdd's Avatar
pdd
Default why shut of traction control?
i can see for the burn out, but wont the traction control give the least wheel spin down the track while floored?
Old Sep 27, 2005 | 06:50 PM
OdessitPashka's Avatar
why don't you try it and tell us the outcome
It will take the power away and slow you down...
Old Sep 27, 2005 | 09:02 PM
SPEEDYws6's Avatar
You would probably have a better et if you spun all the way through 1st and 2nd than if you had tcs on.
Old Sep 27, 2005 | 10:20 PM
CrawlinWS6's Avatar
Import Patrol
unless you like bouncing the rpm up and down, turn that **** off
Old Sep 28, 2005 | 09:21 AM
y2k_ta's Avatar
'Bird Director
From: Central Indiana Honors: 4th grade spelling bee contestant
It regulates your wheel speed to avoid spinning. To do that, it would have to automatically apply the brakes. When I'm leaving the starting line, the only thing that should be applying the brakes is my foot when/if it's necessary.
