Drag Racing Tech
Guys going from BFG DRs to MT DRs
Old Sep 28, 2005 | 01:03 PM
Little G's Avatar
Default Guys going from BFG DRs to MT DRs
After four sets of BFGs, I've decided to switch to the M/Ts. Has anyone else gone through the same transition? If so, what did you do differently?
PSI?
Launch?
Burnout?
Thanks
g
Old Sep 28, 2005 | 01:24 PM
john shea's Avatar
I'm running on worn out bfg's and thought about
M/T's . You are running 13's with a 6 cylinder.
Is that true I have never heard of a 6 that fast.
John
Old Sep 29, 2005 | 12:34 AM
fast01's Avatar
I went from BFG's to MT's, I love the MT's! As far as your questions go:
I run higher pressure w/ the MT's, about 20-22 lbs. as compared to 15lbs.
They need much less of a burnout and I didn't change my launch technique.
Old Sep 29, 2005 | 07:28 AM
Little G's Avatar
cool, thanks
Old Sep 29, 2005 | 08:09 AM
gator's 99TA's Avatar
20-21 psi (and yes i tested lower down to 15 psi - just worse traction issues). i do a big burnout, enough for smoke to roll out of the fenders. didnt change my launch technique at all. went 1.4 60' twice last time out.
Old Sep 29, 2005 | 11:28 AM
Little G's Avatar
Don't think I'll be getting 1.4s but I hope to be in the 1.7 range.
g
