How much more traction expected at track??
I have never ran at the track and want to know if it will be not worth it to go up their without DRS or slicks. Can you guys give me an idea of how much more traction I could expect to have at the track?
can some one give me an idea how I should try to launch. My sig. has my set up. THANKS A LOT!
IMHO, (I can see the flaming now) BFG's drag radials are junk unless you have a suspension and sometimes trans/gear/motor set-up to allow the car to launch where the tires will hook up well. Don't forget that drag radials usually don't have as flexible a sidewall as et streets or slicks (going in order of flexability). A car like a 72 Chevelle will need that to hook well. I had a 72 Chevelle with a very mild 350, turbo 350 trans with 2800 stall 11" convertor and 3.55 gears pull 1.82 60 foot times and run mid 13s at 100 mph over 10 years ago, and if I can scan pictures of it launching on 26 x 8.5 ET Drag slicks you'll see the sidewalls were wrinkling up good.
Hope this helps out somewhat.
Derek
I am new to racing and not to sure of best launch or rolling the peddle. I am not sure if the track surface will help my tires hook up better.
I am running a 4:11 and 28" tires. I am nut sure if a better gear would be a 3:50 or so. I did the math, I think it said at around 120mph the thing will shift out of third with 4:10s All help is gladly accepted. thanks
