Drag Racing Tech
Torque arm question?
Old Oct 8, 2005 | 07:38 PM
CrawlinWS6's Avatar
Import Patrol
Default Torque arm question?
When I was getting my trans built, I had the shop throw in a spohn adj torque arm. My problem is that before the new torque arm, I has using the oem ta and 26inch et streets, and managed a 1.5 60fts, now with the new torque arm and 28inch hoosier slicks, I could not get anything better thana 1.68 60ft. So Was thinking that the ta may need to be adj. since it was never adj since it was put on. I was told that the ta should of came with a level tyoe tool to adj the degree. But I do not have one. Is there another way to sdj the ta, or where can I pick the tool up, and what degree should it be set on?
Old Oct 9, 2005 | 06:15 AM
Mark98SS's Avatar
Do a search for pinion angle, you will get plenty of info.
Old Oct 9, 2005 | 12:33 PM
zeeya's Avatar
I got a gauge at sears. Just anfgle finder. I have the same TA. Helped me out alot. I have mine set at -2*
Old Oct 9, 2005 | 01:13 PM
CrawlinWS6's Avatar
Import Patrol
Where do you put the angle, or anywhere should work.
Old Oct 9, 2005 | 03:20 PM
zeeya's Avatar
This is the way I do it. And it seems to work. When you lift the car make sure its the same as it is on the ground. Load the rear suspension. Check your transmission angle. I got mine level. with the car. Then put a angle finder on the pinion yoke. Read the measurment. Then check it on the driveshaft. Set the rear pinion so there is -2 on the rear. You might want to check with madman or one of the other suspension guys to see how they are setting cars up.
heres a post I made about the difference in my TA. PICS.
https://ls1tech.com/forums/drag-racing-results/389207-before-after-torque-arm.html
Old Oct 9, 2005 | 03:57 PM
CrawlinWS6's Avatar
Import Patrol
cool thanks
