Drag Racing Tech
icing LSx intakes
Old Oct 21, 2005 | 07:54 PM
slowpoke96z28's Avatar
Default icing LSx intakes
being composite and not metal, do LSx intakes benefit from icing between runs like metal intakes do?
Old Oct 21, 2005 | 09:03 PM
mcamp001's Avatar
I think you would want to run at just about 180-190 degrees, so if you change the stock Stat and re-program the fans, there would be no need to ice anything down. Doesn't exactly answer your question I know, but running cooler then that may hurt more then help.
Old Oct 21, 2005 | 09:34 PM
Wnts2Go10O's Avatar
it would probably benefit u more if u cooled down the lid, bellows, etc more than the intake manifold
Old Oct 21, 2005 | 11:16 PM
mongse's Avatar
I ruin the end of films...
It won't hurt. Of course, your heat transfer won't be the same as with an aluminum intake.
