harlan 2 step how to??
LS1TECH Sponsor
I ran one wire to the hatch release and one to the PCM pin for the clutch switch. Push the hatch release with the clutch in, and it was armed. Release the clutch and it was off. Worked great.
Now I gotta figure out how to wire it into the t brake.
Which wires go where?? isnt there three wires??Thanx for the help
LS1TECH Sponsor
White wire to the hatch release and other wire on hatc release to ground. Then It's the blue connector on the PCM, pin 32. Should be a gray wire. That's the clutch
input for the 99+ PCM's. Tap directly to that wire with the gray wire from the
2 step.
Yellow wire is not used unless you have nitrous.
2 step.
