Drag Racing Tech
Quickest full weight bolt on M6 ?
Old Nov 15, 2005 | 04:22 PM
BADSZ28's Avatar
That was on a 4.10 gear with LCAs and LCA brackets, free mods, cut-out, bellows, lid/filter, Vara Ram V. Stack, Torque Arm, Skinnies, MT ET DRs, Pro 5.0, Pulley, HP tuned by myself on street, Drill mod, mighty vac bleed, SFCs, shift light, line lock, shifting at 6200. I think I may have pulled an 11 if I shifted at 6400 and got a little better 60 since I only got a 1.69 on that run and did a 1.65 on another and power shifted into 2nd. The clutch would slip if I powered into 4th. All else is stock. I have to get a 9" since I blew the planetary gears in the Torsen that day.
Old Nov 15, 2005 | 05:21 PM
TRex's Avatar
Dude, I think you have the record for through the manifolds, that is a crazy time ! Good driving !
Old Nov 16, 2005 | 09:15 AM
BADSZ28's Avatar
No, I know of two other guys who went 11.9. But I do not think they were full weight and they both had to be -DA. I know I can do it if I shift at 6400 in near 0 DA.
