Drag Racing Tech
Help me out with my math!
Old Nov 14, 2005 | 12:04 PM
Dustin's Avatar
Default Help me out with my math!
Car weighed in at 3320lbs on 11/12/05 with ½ tank of gas before strut bar and brackets removal which was 14lbs. So that is 3306lbs minus whatever the gas is. It was exactly on 1/2 a tank, I just dont know how many gallons that is or how much gas weighs per gallon.
Old Nov 14, 2005 | 12:07 PM
bad2000ss's Avatar
6.5lbs per gallon usually.
The tank should be 16.5 gallons total.
If your gauge showed 1/2 tank you probably had between 7-8 gallons left.
Old Nov 14, 2005 | 12:10 PM
Dustin's Avatar
So say 6.5 x 7 = 45.5 + 14lb sway bar = 59.50. 3320 - 3260.5lbs total. Sound about right?
Old Nov 14, 2005 | 12:16 PM
bad2000ss's Avatar
did you add a sway bar or delete one?
Little confused???
Old Nov 14, 2005 | 06:28 PM
Dustin's Avatar
Little confused???
delete
Old Nov 15, 2005 | 09:16 AM
bad2000ss's Avatar
3320lbs (Car with 1/2 tank of gas) - 14lbs = 3306lbs.
Old Nov 15, 2005 | 09:20 AM
Dustin's Avatar
Yah i know, and subtract the 45.5lbs of gas gets the car at 3260.5lbs. I have to take that gas off, with gas doesnt show the actual weight of the car.
