Drag Racing Tech
Need speedo help quick!
Old Nov 17, 2005 | 12:20 PM
Dragaholic's Avatar
9 Second Club NA
Default Need speedo help quick!
I'll be hitting up the track tomorrow evening and I have a speedo problem. When I swapped to the TH350, I left speedo sensor unplugged and it set off a code in which set my rpm rev limiter back to stock. Anyhow, I ran that plug into the front wheel sensor and had the computer programmed to have a 2.76 gear ratio and a 26" tall front tire. Well I now have the Strange front drag brakes and it no longer retains the sensor. What can I do in the meantime? I dont have time to modify the rear housing for a bung, sensor, and reluctor wheel. If I leave it unplugged, I would assume its going to do the same thing. WHAT DO I DO!
Old Nov 17, 2005 | 01:25 PM
12secSS's Avatar
What are you using to tune with? Just deactivate the SES code for the VSS signal. That is how it is done on Jen's Z28, we have no speedo input at all.
Old Nov 17, 2005 | 06:13 PM
Dragaholic's Avatar
9 Second Club NA
I have a full custom dyno to by Mike @ G-Force. I'll pass it along to my tuner and have him do that. Thanks for the help!
