Help my 60'
At the beginning of the season on 26" ET streets with less nitrous (NX100 that only gave 60 on the dyno, turned out to be a restriction in the feed line) I pulled a 1.63, 1.69, and low 1.7s best ET then was 11.56@115.5 on N20 (N/A pass that night was 12.18@111 I believe) and that was on Madman LCA's & an otherwise stock suspension, stock wheels. I now have Hals W/300# spring up front set at 2/2, Z28springs rear 1/2 coil cut & rubber buffer removed, boxed SFC's, air bag(20-25# depending on prep), bogarts slicks/skinnys & some weight reduction of the front end.
Are the 27" tires affecting my launch that much? I really didn’t want to put any money into my 10bolt, though I may just stick some 3.73's in it and see what happens. I bought the wheels used with the new 27's already on them, I might go back to 26". How much of a gear ratio drop is it going from a 26" to a 27" tire when you have 3.23's?
