Drag Racing Tech
Using nitrous?
Old Nov 23, 2005 | 04:49 AM
DD966's Avatar
Question Using nitrous?
My 100 shot kicks in @ 3000 rpms (MSD window swtich w/pills). I'm on stock tires, stock rear 'n gears. I can probably reduce my 60' to 2.1 - 2.2 , but I'm having troubles with spin, the moment I shift into second. In fact, I spin most of the way through second.
My question is... should I wait to activate until after I shift into second? Does anyone do that? I've only made 3 passes with my N2O, and I've tried feathering it a bit, but I still spun like crazy.
Thanks in advance, Jim
Old Nov 23, 2005 | 08:53 AM
WickEdSix98's Avatar
You need to invest in some sticky tires otherwise you won't ever get rid of your problem.
Old Nov 23, 2005 | 08:55 AM
Dustin's Avatar
If you get the BMN window switch you can lock first gear out
Old Nov 23, 2005 | 10:15 AM
SSDriver's Avatar
Get some sticky tire's. I spray a 150 shot trough shifts on MT et street radials and they don't even chirp if I do a nice burnout.
