Drag Racing Tech
light weight battry? where to get one?
Old Dec 2, 2005 | 12:54 AM
Abdullah's Avatar
Default light weight battry? where to get one?
the light weight bettry is a dry cell battry, right?
where can i get one?
for how much?
and for how long it will be active?
and how much weight exactly i can save with one?
thanks.
Old Dec 2, 2005 | 06:38 AM
GM Muscle's Avatar
Gotbatteries.com carries a full line of odyssey (sp?) batteries. My 13lbs PC680 was $75 or so and it hasn;t given me any problems in the past season.
Old Dec 2, 2005 | 06:59 AM
Abdullah's Avatar
how about optima battry? isn't optima battry a light weight battry?
Old Dec 2, 2005 | 09:12 AM
1999TransamWs6's Avatar
my optima yellow top weighed in at 45lbs the battery GM Muscle has is 13lbs like he said so 32 lb difference and if he says no problems its got my vote. Im buying one after christmas (waiting to see what I get ) Hope this helps.
Old Dec 2, 2005 | 09:34 AM
Bryan @ Speed Inc.'s Avatar
PM TMC he has a few of these 13lb batteries never used. i just bought one from him. $65 shipped.
Old Dec 2, 2005 | 10:02 AM
Matt D's Avatar
Retired Street Racer
Hawker Odyssey PC680
Old Dec 2, 2005 | 04:03 PM
Racer8102's Avatar
Hawker, just arrived yesterday, about 100 shipped, super small and light.
Old Dec 2, 2005 | 09:26 PM
Nate_Taufer's Avatar
Search is your friend. pc680 is the most widely used batt on this board.
Nate
Old Dec 10, 2005 | 04:39 PM
NOTFAST's Avatar
Are there any batteries that work as well as a stock one but weigh less? basically, i need something that i can keep my bottle heater on and still start the car
Old Dec 10, 2005 | 09:19 PM
GM Muscle's Avatar
With this battery you will not want to run the bottle heater without the car running (might be ok for a few minutes). However, my car has both underdrive pullies and it can easily sit idling in the lanes with the lights on and the bottle heater on and then restart no problem if I have to shut the car off for some reason.
Old Dec 10, 2005 | 10:27 PM
WicketMike's Avatar
The Hawker PC680, can you use it for daily driving also? if not, how much can you really use it on the street?
Old Dec 10, 2005 | 11:40 PM
chpmnsws6's Avatar
why not a 12 volt lawn mower battery? there have been a few people around here running them. 20-25 bux and weighs less then 10 pounds. it fired the cars right up as long as you didn't play your system or leave your lights on.
Old Dec 11, 2005 | 03:43 AM
Please re-read the responses that were already given. I already stated that this is the most widely used battery on this board, daily and track driven. I have used this battery for about 6 months daily driver and no bad ju-ju to speak of.
Nate
Old Dec 11, 2005 | 07:58 AM
Larry's Avatar
Here's the battery I have: http://www.gotbatteries.com/Productp...ctNum=37L105S1
Here's how I mounted it: http://www.mustangmods.com/data/440/battery.jpg
I can go back to a factory style battery in about 10 minutes. With these adaptor arms I kept the same connecting bolts to battery.
Old Dec 11, 2005 | 12:27 PM
NA$TY-TA's Avatar
HMMM thats got me thinking..... -32#'s there for me over my Yellow Top Optima. cant beat that for around a $100. Ill have to pic one up.....
Does it work any harder to start cars with the battery in the hatch like mine is???
Kyle
Old Dec 11, 2005 | 03:12 PM
Kyle
It probably wont be able to start the car in a rear mount unless you're running some stupid large batt cable. I wanted to do the same thing as well but all i came up with in the search function is that little batteries and remote mounting do not work well together.
Nate
Old Dec 11, 2005 | 03:28 PM
TS6's Avatar
TS6
Kyle
Just install it up front, it weighs 13 lbs. Also it saves all the associated wiring and hassle with a relocated battery.
Old Dec 11, 2005 | 03:34 PM
GM Muscle's Avatar
Nate
Yep, my searching has come up the same in the past. The only person I found running one in the back without problems is Mighty Mouse. I imagine he's running 1ga welding cable or something like that.
Old Dec 11, 2005 | 03:50 PM
NA$TY-TA's Avatar
Kinda hard to put a Battery back up front when this is in the way...
I do have 1/0 gauge wire ran from the front to the back...... so i cant get much bigger there I guess ill use the Optima i have until i just buy it and find out.
Kyle
Old Dec 11, 2005 | 04:21 PM
NOTFAST's Avatar
Im thinking the 925 is best for a car with maybe a stereo or a few nitrous accessories
thoughts?
