Front end
-AJE K-member
-AJE A-Arms
-AJE Manual Rack
-AJE Spindle set-up
-Wilwood Lightweight brakes
-175lbs
-Pro star skinnies/Tires
-50 lbs
-Lightweight battery
-30lbs
-Remove power steering
-15lbs
-Remove ABS
-15lbs
-Remove TCS/ASR and cruise control
-15lbs
A total of 300 lbs on the nose.
Was wondering what you all thought this would do for my set-up. Im sure it will be substantial but how good will it be? My 60' currently is 1.71 and quarter on muscle is 11.7 What kind of gains could i expect to see? Also you think ill be able to pull some wheelies?!?!
. Thanks guys -AJE K-member
-AJE A-Arms
-AJE Manual Rack
-AJE Spindle set-up
-175lbs
-50 lbs
-30lbs
-15lbs
-Remove ABS
-15lbs
-15lbs
. Thanks guysskinnies is about right 65 lbs if you get ET fronts instead of radials
light weight battery more like 20-24
power steering more like 10lbs
ABS more like 10 lbs
TCS/ASR module more like 8 lbs
-SUX2BU Wasnt shure for all the removals but the suspension set-up is proven at 175-200 lbs off the nose according to either drag bracks or street as well as tie rod ends or not and I went with bushings and street brakes and I was told 175lbs but only a before and after weight will tell us the truth
