Drag Racing Tech
need help....!!!!!
Old Dec 13, 2005 | 08:12 PM
crazy camaro's Avatar
Default need help....!!!!!
ok went to the track this weekend with my new setup and here is what it is
12 bolt 3:73's
full suspension
built trans w/pro yank 3600 stall
patriot ls6 stage 2 heads 2.20/1.60 and 66cc
crane cam 216/224/115lsa
ls6 intake and slp maf and flo-pac induction
asp under drive pulley
hooker lt's off road y-pipe
corsa cat back
crane tuner used
ok here is my time best 12.55@112 mph and the problem i had at the track was this a leaking line lock that caused my pedal to drop to the floor so no stall was used really.That time was just flat footing it out of the hole and also this converter feels real tight i fixed my brakes by taking the line lock off and just useing stock break line but it wouldn't stall past 1700 without the car lunging i think this setup should have done better any suggestions...????
Old Dec 14, 2005 | 07:00 PM
nobody knows anything that i could have done wrong???
