Drag Racing Tech
Line Lock?
Old Dec 15, 2005 | 09:01 AM
96 LT-1's Avatar
Bad Seller Warning!
Default Line Lock?
http://www.bmracing.com/index.php?id...s&sid=3&cat=16
anyone have this line lock?
do you still have to hook up to the brakes or does it do it all electrically?
Old Dec 15, 2005 | 09:35 AM
AL SS590 M6's Avatar
All line locks have to be hooked into the hydraulics of the brakes. That's how they work. Locking the fluid @ pressure in the calipers for the fronts so that you can let off of the pedal and release the rears.
For an experienced mechanic the install is cake. Bend a few lines, put some nuts on and flare the tubes.
For an inexperienced guy the kits available from Thunder Racing and others make it the same cake. The bending and flaring are all done for you. The actuall install is simple.
Old Dec 15, 2005 | 09:57 AM
02Z28's Avatar
Check out SJM they have a really nice kit for the LT1's and the lines are pre bent for you.
Old Dec 16, 2005 | 03:12 PM
DOUBT IT's Avatar
