Drag Racing Tech
what do u think i can run?
Old Feb 10, 2006 | 07:21 PM
98TADRIVER's Avatar
Default what do u think i can run?
the question thats been asked many times: what do u think my car can run? by this spring, i will have quite a bit done, as follows im thinking low-mid 12s?
old time in sig.
My mods (some done already) by early this spring that will be complete-
all free mods (if that means anything, lol)
Intake: Lid, FTRA, K&N ported TB and MAF
Exhaust: LT's ORY magnaflow catback
UD crank pulley
spec stage 3 clutch
9inch with 4.11 gears,
adj torque arm, adjustable rear shocks and "Z bars" or "madman bars" (as theyre known by.)
Subframe connectors
Denny's nitrous ready driveshaft (for the summer/fall season when i spray)
drag radials. thinking of around a 28" tire so i can stay in 4th gear
battery located to rear
and maybe skinnies
no weight reduction, 3660 lbs with me in it (1/2 tank of gas)
i can shift pretty good too--> shifting the T/A
Old Feb 11, 2006 | 12:32 AM
Ls1LikeNoOther's Avatar
I would think you should be able to go low 12's...I had a stock motord 2000 ls1 ta full weight with full suspension(minus front control arms and k member) with the stock airbox and only a flow master muffler for exhaust it went 12.50's with an a4..
6 speed full suspension car should go low 12's with those mods i would think..
Old Feb 11, 2006 | 12:10 PM
98TADRIVER's Avatar
coooolll thats what i was figuring on
