Drag Racing Tech
Can I get some help MADMAN ?
Old Feb 14, 2006 | 03:37 PM
smokeum99ta's Avatar
Default Can I get some help MADMAN ?
I recently bought and installed a moser 9inch rear. My torque arm is giving me problems. It hits the floor pan and trans tunnel (see pic for the one I have). I was looking at your TA on your site. And your arm looks like something I could fab up myself. Not trying to be a cheap *** but I do take pride in doing things myself ,im a ironworker and cert. welder and know it's something that I could easily do. I was wondering want you use for the ends on the TA? Do you use weld up bung's(spl) or have the inside of the pipe threaded for the ends. I was just gonna use the existing mounting plate in the trans tunnel and make the TA sit in front of the rear instead of off to the side. Thanks for any help and please let me know if see any issues with what i'm gonna do. Ken
Old Feb 14, 2006 | 04:20 PM
MADMAN's Avatar
LS1Tech Sponsor
I use Aircraft grade chromemoly rodends. I also use all chromemoly tubing with chromemoly weld in bungs.
__________________
www.madmanandcoracing.com
225-343-9029
Old Feb 14, 2006 | 04:33 PM
Alright then, thanks. Do you think threading the inside of the pipe is useless? just weld on the bungs and call it good? I'm just concerned with strenght thats all.
Old Feb 14, 2006 | 04:34 PM
MADMAN's Avatar
LS1Tech Sponsor
Threading the pipe is weaker than the bungs. They slip inside the tube and then get plug welded plus perimeter welded.
__________________
225-343-9029
Old Feb 14, 2006 | 04:39 PM
Thanks for your help.
