mt drag radials with m6 please come in
Add good adjustable rear drag bar to the above
I'll be trying a set of Draglites and ET Streets soon.
I've got some friends that have run the ET radials with good results.. but they aren't M6 cars
so far i havnt like them my DR were way better.
the bad part is i cant get the DRs in a 27in like my streets are in.
for a drag car or weekend warrior id get front and rear adjustable shocks, front drag springs, rear drag bar, chasis mount torque arm or the tranny relocation crossmember like im running and the lca relocation brackets and contorl arms, if you tune it right it will hook
i have them on my car and im launchin at 6000 just dropin the clutch and the car just dead hooks and that is on 255/50/16s. the wheels lift pretty good
i have 400hp and 393tq at the rear with a 12 bolt with 4.11s.
i also have full suspension...spohn lca, panhard, tunnal mount TA, subframes, lca brakets at the lowest hole, rear hal f shocks with stock springs set at 4/5, front hal r shocks with 325 spring set at 1.
I noticed my rear swaybar had twisted around the 12-bolt. I had a stock swaybar with 3" muffler clamps and poly bushings and endlinks. The muffler clamps had rotated on the rear end. I'd snugged 'em half a turn past Jesus tight, so I figured it was time to do a real drag bar.
The Wolfe welds 2 brackets to the axle tubes, and then welds tabs to the rear frame rails. Solid heim joints connect the rear bar (that goes between the 2 brackets) to the rear frame rails. This sucker won't twist.
I had a right rear airbag, and was still seeing a lot of suspension twist. Hoping this cures it. It'd be too radical for the street (IMO), but my car's a track car now. I think the BMR drag bar is more streetable, but operates along similar lines.
im stuck in the 1.60 1.65 range with my hoosier, trying to figure out if moving to the radials are going to hurt, or help.
