Drag Racing Tech
Paging MADMAN Adj A Arm Questions
Old Feb 24, 2006 | 12:47 PM
fash00's Avatar
Default Paging MADMAN Adj A Arm Questions
I got adjustable solid rod end upper and lower a arms how do these need to be adjsuted before they go on the car? I know when the car is done im going to have to get someone to set all the suspension so ill probably jsut bring it to thunder and get you to do it but need to know somehwat how they should be when put on the car
Old Feb 25, 2006 | 01:49 PM
MADMAN's Avatar
LS1Tech Sponsor
What I do is measure out the factory control arms then set up my new ones to the same length. That will get you in the ballpark.
__________________
www.madmanandcoracing.com
225-343-9029
