Drag Racing Tech
M6's that hook on the street
Old Feb 25, 2006 | 07:03 PM
BAKED's Avatar
Default M6's that hook on the street
If there are any, LOL I would like to know what is working for you. I am getting ready to do some suspension upgrades and would like your input. Thanks
Old Feb 25, 2006 | 09:31 PM
Shon Herron's Avatar
When I had my car on the street with SS wheels/315s and if we were on ET Streets it hooked up very well with the 4.11s.
Rod ended Spohn Adj TA (-2*), Rod ended LCA and PHR.
IT has not been on the street much with the 4.33s/spool but it seems to still bite pretty well.
I do not think most have such success as I have had, I wonder if the stock clutch slipped enough for it to hook. Dont know but it sure does work on the track (see sig)
Old Feb 25, 2006 | 10:31 PM
1BADAIR's Avatar
I want to know too.
I can't even hook at the strip
Old Feb 25, 2006 | 10:46 PM
1QuickT-A's Avatar
Definately get some adjustable shocks like the QA1's, Comp Eng., etc.. A nice adjustable torque arm, some adjustable rear control arms, etc should do the job. And if you are running lowering springs chunk em in the garbage..
Old Feb 25, 2006 | 10:54 PM
chpmnsws6's Avatar
rear QA1's, heim jointed LCA's, now front sway bar, larger rear swaybar, big'n'lils on Hoosier QTP's............. thats enough to snap your rear end like a toothpick.
Old Feb 26, 2006 | 09:39 AM
SLowETz's Avatar
QA1 12 way "R"s all four/coil over in rear, QA1 325/150# springs, !front sway bar, BMR chassis mounted(adj. instant center)adj. TA, Wolfe adj. rod end linked weld in rear drag bar, adj. LCA's, Global West SFC's, 28-12.50-15 ET Streets on 4.56's.....
Good to go-
Swapping over to a full man. reverse TH400/Yank 4600/T-brake set up in a few weeks.... have NO idea how it's gonna act
Old Mar 2, 2006 | 01:25 PM
tboysen00's Avatar
i cant hook at the track but on the street compared to other cars i do ok. usually around 3000-3400 and slip it out. its not the fastest or the best. but on stock 10 bolt with dr and no qa1's thats about all i can do.
