Drag Racing Tech
Is removing rear sway that bad?
Old Mar 5, 2006 | 12:57 PM
ninetres's Avatar
Default Is removing rear sway that bad?
I have a 2001 ss camaro M6 that only has the basic bolt-ons.
Is removing the rear sway completly, a bad thing? I have driven it a little w/out it, and there is definitly a lot of body roll, but am I better off (for 1/4 mile) with it in or out?
Thanks, and I'm sorry if this is a no-brainer, I'm learning.
Old Mar 5, 2006 | 01:10 PM
sickss228's Avatar
I've never heard of taking out the rear sway bar for the track, I take the front bar off so the car launches better.
Old Mar 5, 2006 | 01:19 PM
TS6's Avatar
TS6
Leave it on. It will help keep the car from leaving unevenly at the track. Thats why some of the fast guys use an even larger rear bar.
Old Mar 5, 2006 | 01:21 PM
ninetres's Avatar
*heads to garage to put that Fu&*%$ back on......damnit*
Old Mar 5, 2006 | 01:26 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I raced without one and drove it like that too, right after my 9" swap in 2000. Car was basically inconsistent at the track and handled like a 1950 Starchief on the street.
Without the rear swaybar the car will do some impressive wheelies where one side is so high in front that your rear bumper scrapes. On the way down though my car would start spinning.
Point in fact, a beefier rear swaybar is useful because the car will leave more evenly. I run the Spohn rear drag bar and love it. Not as stiff as the ones that weld on all four corners, and the car is still enjoyable to drive around.
Old Mar 6, 2006 | 03:49 PM
ApacheDrill's Avatar
Thats classic.. I think this is one place that bigger is better.. I always wondered about the metal bar that runs across the top of the Pan Hard.. but the rear sway bar is a must..
Old Mar 6, 2006 | 03:55 PM
ninetres's Avatar
Yea, I ditched the upper pan-hard support too. I re-installed the rear sway, and yes it is much stiffer around corners, but the transfer doesn't feel quite as strong (could all be in my head though )
Old Mar 6, 2006 | 04:28 PM
LS1Tech Co-Founder
I run no upper panhard.
Trust me you want the rear sway bar on there. Without it the left front of the car will lift up impressively, but it's not the long term way to go.
Old Mar 6, 2006 | 04:44 PM
ninetres's Avatar
Its on there. I know good advise when I hear it. Thank you.
