Drag Racing Tech
Drag Wheel and tire question
Old Mar 19, 2006 | 02:57 PM
Packy's Avatar
Default Drag Wheel and tire question
What is the biggest tire that I can fit on the rear of my car with a set of 15" X 10" Prostars with 7.5" bs? I am planning on using MT ET Street Radials. I was just curious what is the absolute biggest size I can fit without narrowing my rear end or mini-tubbing. I have a Moser 12 bolt rear(3.73's) and I am not looking at using any kind of spacers. I was thinking 275/50 R15 or 275/60 R15, but after searching a few posts on here I see people using bigger tires with similar set-ups. Is that the right backspacing if I use those tires? I have already done the BFH mod to the inner fender wells and removed the metal bracket from the bumpstops because I have 17" X 11" wheels on the rear for the street.
Also for the front tires I am planning on going with some 15" X 3.5". What backspacing would I have to get to run these. Would I have to use spacers at all on the fronts?
One more question for you guys. Right now I use a set of 16" Firebird wheels with 27" ET streets on them. How would going to a 28" tire efect my 1/4 mile times? Any help would be greatly appreciated.
Old Mar 19, 2006 | 03:04 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
275-60-15 MT DR's will fit easily, they are comparable to a 28x11.5x15 ET Street.
Now a 325-50-15 Might be tight on the inside.
I've run 28x10x15 ET Drag on my Formula, on 15x10/7.5 Pro Stars.
Check out www.wheels.ls1tech.com, it's a wheel gallery I am putting together.
I'm running 28W's on my Bogarts now, so I know that 325 DR's will fit without issues, since both are like a 28x11.5 slick (12 inchs wide.).
And the taller tire will lower your rpms.
Old Mar 19, 2006 | 04:22 PM
30thz's Avatar
Damn Cory, you must be reading my mind I was going to search this and here it was. looking at a set of 15 x 10 Bogarts w/ 5.25 backspacing and was wondering on what tire to run.
Old Mar 19, 2006 | 05:28 PM
1QuickT-A's Avatar
I hope you have a narrowed rearend if you plan to run those Bogarts with a 5.25 backspacing...
Old Mar 19, 2006 | 05:37 PM
30thz's Avatar
That was the other thing I was wondering I was buying them used and was going to call SJM tomorrow to see if they fit a stock width rear.
Thanks for the update.
Old Mar 20, 2006 | 02:55 AM
Packy's Avatar
Yep, I am making my car a straight drag radial car when I get back. Plus I am going to try and put it on a small diet. Add a few more go fast parts and smoke Rich's new Supra he is building! That guy is such a clown!
Old Mar 20, 2006 | 02:59 AM
Packy's Avatar
That is an excellent site! Thanks for the info!
