ANy HP guesses for me?
Stock crank repolished,eagle 6.125" rods with ARP pro bolts,Diamond pistons 3.905" bore -1.6cc dish, I have a custom ground hyd roller cam
int.250 exh.258@ .050
.625 .627 lift 1.7 rocker
108 LSA
the heads are fully ported and polished stock ls1 heads off 99 camaro,I have cut the spring pockets for coventional style 1.430" springs,titanium retainers and keepers,harland sharp non adjustable 1.7 rockers,fast intake with throttle body,MSD coil packs,msd wires,ngk plugs,QTP Heads..Also the crank in addition to being hard chromed,it was microblued as well as cam bearings rod bearings main bearings and the camshaft itself..
This is going in a 98 camaro,complete tubular front suspension,lightweight drag brakes,alston rear suspension,moser 9 inch 4.50 gear,29" tires,mini tubbed,rebuilt t-56...
So what kinda HP numbers should I get and what should this thing do in the 1/4?
