Need help on Battery Relocation
http://www.ws6.com/batt-relocate.htm
I have a couple questions first the guy uses a distribution block(SDBO1448L) for connecting the wires up front. He's running a subwoofer/audio system and I know you need distribution blocks for those. I'm not going to run a system in my camaro. I just want the battery in the rear for racing. Do I still need that distribution block or can I still use that for my set-up... My last question is I'm also putting a flame river push/pull switch on the car.----Do I run that 0 gauge wire from up front to the switch and another wire from the switch to the positive side battery??
Theres no on/off switch, just a 200A fuse. I used #1 cable and it worked fine. You need to run another wire so your alternator doesnt keep your motor running when you turn the switch off. If you search this forum you can find information on the wiring.
Goodluck,
Dale
More info,
https://ls1tech.com/forums/showthrea...hlight=battery
