Suspension advice needed
Chassis work: BMR K-member and A-arms, UMI chassis-mounted torque arm, BMR rod-ended moly LCAs, stock panhard
Suspension: stock front, stock rear springs with Lakewood 50/50s
Tires: MT drag radials 235/60/15
This is a stick car and I launch from 5200rpm. When I launch, if I let out of the clutch too rapidly, it noses up and then bogs so I have to give it just enough so that that does not happen. With this technique, I've managed to get 60fts in the 1.81x range consistently.
I've pretty much decided that the QA1 double adjustable front coil-over setup is the way to go. As for the rear, I've been looking at Spohn's rear coilover setup which uses the same shocks.
My question is what kind of spring rates I should be going with or any other advice you can offer. I'd like to get 60fts down in the low 1.7x range. Any thoughts are appreciated.
g
g
Why not go with 93-97 rear v6 springs.
I run them and you can pick them up cheap.
Your car has the same rear springs as the v8's of that same year
I'm at mid 1.7's N/A
Old set up high 1.5's on the bottle
New set up w/ the bottle.... dunno yet.
