Drag Racing Tech
Tubing thickness.
Old Apr 6, 2006 | 09:03 AM
1936FordPU's Avatar
Default Tubing thickness.
What is the thickness and size of roll cage tubing most people use that will pass NHRA tech?
Trying to order some tubing to make some things with.
Old Apr 6, 2006 | 09:58 AM
JRcamaroZ28's Avatar
4130 Chromoly or Mild Steel?
Old Apr 6, 2006 | 10:33 AM
1936FordPU's Avatar
both...
Old Apr 7, 2006 | 02:33 AM
y2khawk's Avatar
depends on the actual bar of the cage (some can be smaller), but the main structure needs to be min wall of .083 (CM) or .118 (MS). A full cage needs min 1 5/8" OD and a bar needs min 1 3/4" OD.
Old Apr 7, 2006 | 09:17 AM
1936FordPU's Avatar
Thanks Harlan. I was looking for thickness on the mild steel numbers..
Looks like im gonna be getting some 1 3/4 tubing with .120 thickness.
Old Apr 7, 2006 | 10:51 PM
LS1SSII's Avatar
With Mild steel you need to get .134 wall. The way the tolerances run .120 wall may not hit the .118 minimum.
