Drag Racing Tech
battery relocation
Old Apr 9, 2006 | 09:02 PM
slolt1's Avatar
Default battery relocation
just want to know if moveing the battery will help ets
Old Apr 9, 2006 | 10:17 PM
matts22's Avatar
Wow that "sentence" was hard to read...my head is spinning...
Old Apr 9, 2006 | 10:49 PM
slolt1's Avatar
is that beter or can you not read that since your head is spinning
Old Apr 10, 2006 | 12:48 AM
matts22's Avatar
I was just messing with you...yes, theoretically it will help your ET, as you are moving weight from the front of the car to the back. This will not only make the front lighter and easier to get off the ground, but will also add weight to the rear to give you traction. I know lots of people do this, but I'm not a hardcore drag guy, so I've never done it. I can't tell you how much it actually helps.
Old Apr 10, 2006 | 12:55 AM
SUX2BU's Avatar
It helps more to swap it out with a lightweight battery. And its ALOT less hassle.
Old Apr 10, 2006 | 06:12 AM
76LS1BIRD's Avatar
Restricted User
More relocation info.
https://ls1tech.com/forums/drag-racing-tech/480741-battery-relocation-will-set-up-work.html
Old Apr 10, 2006 | 10:47 AM
slolt1's Avatar
thanks for the help
