Drag Racing Tech
Alston torque arm need brackets modded?
Old Apr 15, 2006 | 03:21 PM
chpmnsws6's Avatar
Default Alston torque arm need brackets modded?
Am I the only one who had to mod the torque arm bracket so the holes will match up? I had to grind a good 1/4 inch off the torque arm bracket on the 9 inch to get it to fit.
Do they have 2 styles or is this common? It was kind of a good thing though, as it puched the torque arm in closer to the center, keeping it off the tunnel a little bit more.
Old Apr 15, 2006 | 05:55 PM
StangEaterSS's Avatar
i know with the moser 12 bolt you have to grind the TQ arm bracket down to get it to fit using the 2nd set of holes on a BMR TQ arm. not sure how the 9" is, but i'd assume you'd have to mod it just the same.
Old Apr 15, 2006 | 06:49 PM
badass 2002 z28's Avatar
No you're not the only one...I had to do the same thing
Old Apr 15, 2006 | 06:50 PM
Ls1LikeNoOther's Avatar
its more often than not the rear ends fault...Your going to have to modify most everything thats a "bolt on" nothing will fall into place..
Old Apr 15, 2006 | 07:10 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
The 9" is the culprit, the Alston stuff was designed with a 12 bolt.
Old Apr 15, 2006 | 07:25 PM
chpmnsws6's Avatar
Sounds good. Actually prefer it this way as long the 9 inch bracket doesn't crack.
That will keep everything in closer to the center and not on the tunnel like the Spohn and BMR. This torque arm seems to have better quality then the spohn and 20 times better then that junk BMR trak pak torque arm
