Drag Racing Tech
Progress on the Z!!*PICS*
Old Apr 16, 2006 | 05:53 PM
monsterls1's Avatar
Thumbs up Progress on the Z!!*PICS*
Pretty much all of the weight loss is done except for the stereo, k-member,lower a-arms. I got most of the suspension istalled, and the Prostars, and tires. I still need to get the cam, cage, rear sway bar, and rearend,and finally the Kirkey's. I"ll get pics up when everything else is done.
Old Apr 16, 2006 | 06:08 PM
CAT3's Avatar
Restricted User
Are you going to trim/remove the excess seam sealer as well? And pass. air bag?
How much of a PITA was it to get the center vent out? I need to pull just that one so it dont throw any heat/ac on the switch panel I made.
Old Apr 16, 2006 | 06:13 PM
monsterls1's Avatar
I never thought about taking out the seam sealer, I will probably do that. I already have the pass. airbag out, along with everything else out from behind the dash! The center vent was very easy, look at it from behind and it is pretty self explanitory I just popped it out with a flathead screwdriver, I will be putting some gauges there and my switch panel where the heat/air controls once were.
Old Apr 16, 2006 | 06:20 PM
skipperbisket's Avatar
i've got a kirkey econo drag with a black padded cover for sale...
Old Apr 16, 2006 | 06:43 PM
monsterls1's Avatar
I already have a Pro street driver's seat, but I want a pass. seat, how much? and how much for the cover alone?
Old Apr 16, 2006 | 06:46 PM
Nate_Taufer's Avatar
You're not gonna **** can the ABS? Or lose the maf and go SD?
Nate
Old Apr 16, 2006 | 07:32 PM
SVT THIS's Avatar
How much weight have you lost on it now?
Old Apr 16, 2006 | 08:01 PM
paid $89.99 for the seat and $59.99 for the cover both brand new and they are both still brand new sitting on the shelf in my shop. make an offer.
Old Apr 16, 2006 | 08:59 PM
CAT3's Avatar
Restricted User
Skipperbislket, send you a pm ref: seat.
Monster, ditto Nates Q's and what is your end state goal with this car if you dont mind me asking?
Old Apr 16, 2006 | 10:37 PM
monsterls1's Avatar
Nate and Cat- I forgot to add that I will be getting rid of the abs when the new rearend arrives, and the SD tune will be for when the new motor goes in this fall/winter.
Skipper-you have a pm.
SVT- I never took the time to weigh everything, but going by the weights in the sticky, I would say about 400lbs. Heat,a/c, front/rear bumper supports, rubber mat on fire wall,all windshield washer accessories,jack/spare,door bars,all plastic under front end, front wheel wells,all chromeoly suspension, interior brackets,rear seats,carpet,etc. I won't take the stereo out until I never drive it on the street anymore!
Old Apr 16, 2006 | 11:48 PM
1QuickT-A's Avatar
The Z is lookin good man! And I agree.. Gotta have the stereo!!
