Drag Racing Tech
Legal wheel stud ?
Old Apr 19, 2006 | 08:32 PM
1STGEN68-2000SS's Avatar
Default Legal wheel stud ?
Ok
We just finished installing the moser 9" with a strange center section. I ordered the 1/2 x 3" screw in studs and when we installed the prostars the studs do not come out beyond the end of the nuts. We are running a 5/16 spacer due to the factory calipers. We are running the full length wheel nuts so they are threaded the entire length. Will these pass tech or do I need to find longer studs.
Thanks
Alan
Old Apr 19, 2006 | 08:41 PM
WILWAXU's Avatar
NHRA rule is basically that it needs to stick out from the rim at least 1 thickness of the stud.
Old Apr 19, 2006 | 08:45 PM
Camaroholic's Avatar
The threads can still be inside the nut - they don't have to come through, but if you have 1/2" studs, they must protrude 1/2" in to the hex threaded portion of the nut (this means 1/2" past the washer, if you're running them).
Old Apr 19, 2006 | 08:50 PM
WILWAXU's Avatar
Straight from the NHRA rulebook 5:2:
"All wheel studs must project into the hex portion of the lug nut by a distance equal to one diameter of the stud."
Old Apr 19, 2006 | 09:00 PM
CAT3's Avatar
Restricted User
Both said the same thing in post #3 & 4, however #2 was worded incorrectly, saying it needed stick out the diam. from the rim...with washers used, as they should be, then it would be a little more needed than the dia.
Old Apr 19, 2006 | 09:03 PM
They are only about 3/16 of a inch from coming out the end of the stud. If I understand the rule this should make it legal due to the hex portion is longer tha 3/4 of a inch.
Thank's for the reply's
Alan
Old Apr 19, 2006 | 09:20 PM
1BADAIR's Avatar
http://www.maritimedragracing.com/id5.htm
Old Apr 19, 2006 | 09:31 PM
Originally Posted by 1BADAIR
A picture is worth a thousand words.
Thanks
Alan
Old Apr 19, 2006 | 11:58 PM
WILWAXU's Avatar
Nice find!
Old Apr 20, 2006 | 09:22 AM
11SECSS's Avatar
I didnt think spacers are legal ? I could be wrong.
Old Apr 20, 2006 | 09:26 AM
12secSS's Avatar
There is a thickness limit on spacers, and IIRC it is about 1/4". But correct, spacers/adapters are not legal.
Alot of people tend to over do it when it comes to studs, that picture is direct from the NHRA rule book.
