Finally done..
Fast 90
Nick Williams 90
Direct Port
Tr 244
Adjustable Chromoly BMR rear suspension
12 bolt strange with 4.10's
Qa1's all the way around with v6 springs up front
Dennys drive shaft
Weight Reduction and cleaning up front..
Let me know what you guys think..
Still need to finish independent fuel system...and it will be ready to spray away..
How big of a shot are you looking at? Tire size? Did you narrow the rear when you bought it?
Good luck. Still waiting to fire mine for the 1st time.
David
The car ran a 7.28 on 100 shot with a TR 236, ls6 intake and stock 10 bolt with 3.23's..
Its about 300 lbs lighter and has alot more gear.. Going be spraying 200 shot.. I should get in a 6's respectivley.. We will see..
Glad to see I could help a little. You are right. The tune will be the key. What a you tuning with - LS1 Edit, HP? Progressive controller? Always wanted to try the progressive controller, come out at 150 shot, progress up to a 250 shot. BUT went another direction. Let us know how it goes.
David
.. HP tuners all the way.. Whats going to throw me off is the indepent fuel system going to the fuel Noids.. jetting will be different then if the fuel was coming from the main feed line.. It should hit pretty hard though once we get the bugs worked out..
I did think about running a swith off my rathchet shifter kicking the Nitrous in on the 1/2 shift, with 1st gear being so low i dont need it out of the hole.. Kinda like the neutral safety switch setup.. then ill have nitrous for 2/3 gear..without the use of a controler, that would be legal
