Is it worth even going?
Here's some suggestions - Leave the tire psi at normal setting. Drive around the water box and leave your tires dry. Power brake the car and spin the tires. The goal is to "clean" them, don't worry about trying to heat them. When you are staged and the lights come down you'll be leaving as soon as you see the last yellow bulb come on. You'll want to try and tap the gas peddle and then floor it as quick as you can after that. It's extremely hard to be consistent doing this but if you get it right you'll launch without spinning.
Good luck and have fun.
Mostly just use your first trip to have fun, learn about the track and meet folks.
