Magnaflows off of Kooks headers!!!!!!
Well i finally got my Magna flow mufflers in. I took off my bullets and clearenced under may car more than i already had for the bullets.
The mufflers are 4"tall, 9" wide and 18" long (22" total). They are a straight thru design just like the bullets, so there is no gain or los in power. But they are 1,000,000 times quieter.
I am so FREEKIN EXTATIC at how quiet the car is. It is about as loud as an LS1 with a mild cam and 3" true duals dumped at the axles. Shaun ("Z4 performance" i think)drove it around and said it is actually QUIETER than his true dual, X pipe dumped at the axle with twisters(full out cam only Trex car)!!!!!!!!!!!! And these mufflers flow ALOT better.
we went to Jake's "black98ls1" house and started his car up and it is 10x louder than mine (another full out cam only Trex car, with twisters off the headers). His car is a hair quieter than my car was with the bullets, it wouldn't even be worth the swap if you had bullets. But he said he is DEFINATLY getting the same mufflers!!!!
After clearencing under the car i actually have BETTER ground clearence than with the bullets! i can fit a whole coke can under the lowest spot and still have almost a 1/4" of clearence.
It doesn't sound as ALL OUT KILLER at idle like with the bullets (that and they are about 5 lbs heavier each are the only down sides) but it still sounds really good. To tell you the truth to me it sounds EXACTLY like a car with some 3" true duals dumped at the axle with bullets and a mild cam.
Inside its 100 times quieter too. And as soon as i start rollin it actually gets QUIETER! When it idles is prolly when its the loudest. Of couse though it still has that exhaust under the car drone inside but i don't mind that as long as oits not deafening loud like it was before. Hell i got on the highway and was doing 80 MPH (4,000 rpm's
I just tacked on the turn down incase it was too loud outside i could turn them facing in. But its perfect just like that so i'm gonna finish welding them Monday. Didn't get any pics of the passenger side, but that side was VERY easy. no clearancing at all. just slid the muffler on the header and added the turn down.
I will get a video/sound clip asap.
This is how it is now.
http://video.ls1tech.com/video/3667E...FD788198FA.htm
this is how it sounded with the "quieted down" bullets
http://video.ls1tech.com/video/92B52...13A8D7570C.htm
I'm going to be trying a full Magnaflow 3" system versus my current Flowmaster 3" system on the Nova soon. Sales guy at Magnaflow says another 10-15 horsepower should be there, and I guess I'll find out!
Let us know how track times go with the new set-up!
Derek
I think mine are burnt out though. They seem to be a lot louder now than when I first put them on 2 years ago. I may just have to buy some more and dump them right off the header too
Brand: Magnaflow Exhaust
Product Line: MagnaFlow Performance Mufflers
Case Shape: Oval
Inlet Diameter (in): 3.000 in.
Inlet Quantity: Single
Inlet Location: Center
Outlet Diameter (in): 3.000 in.
Outlet Quantity: Single
Outlet Location: Center
Internal Construction: Perforated stainless tube with packing
Muffler Material: Stainless steel
Muffler Finish: Natural
Case Length (in): 18.000 in.
Overall Length (in): 24.000 in.
Thickness (in): 4.000 in.
Width (in): 9.000 in.
Outlet Style: Standard, without tip
Quantity: Sold individually.
