T-56 launch technique help
Once u step on the line make sure your traction is off and lunch at 3000RPM using only clutch and gas( Dont worry the track surface is flat so the car went roll ), and you r good to go.
Practice on the burnout as u can before you go to track so u can be ready and not **** ppl and your self .
I'd try and go around the water if you can. Do a small burnout, just enough to see a little smoke to clean the tires off.
If you have to go through the water then so be it, just do the same thing.
In either case, you should hold the brakes down after you start the burnout. I would think it would be very hard to heel/toe this car.
I would launch lower like 2000-2300rpms, letting the clutch out somewhat slowly. Don't dump the clutch.
try going around the water box and then back up to the edge of the water and then do the burn out. the spotter will help.
