Drag Racing Tech
How To Battery Relocation
Old May 9, 2006 | 07:57 PM
dnkynrbk's Avatar
Default How To Battery Relocation
Just wanted to know if there is a battery relocation how to and what do I need to put my ground wire to in the back. thanks guys
Old May 9, 2006 | 08:04 PM
monsterls1's Avatar
There are a ton of posts about battery relocation if you try a search, they may get into more depth. Pretty much just run your positive cable from the stock location under the hood under the carpet to the battery. Then most people ground the battery to the backseat seatbelt bolt. Or you could bolt it to the frame or body, I just drilled a hole behind the rear tail panel and bolted the neg. cable to it.
Old May 9, 2006 | 08:14 PM
dnkynrbk's Avatar
thanks man
Old May 10, 2006 | 05:15 AM
76LS1BIRD's Avatar
Restricted User
https://ls1tech.com/forums/generation-iii-external-engine/388581-battery-relocation.html
Old May 10, 2006 | 09:38 AM
Bitemark46's Avatar
But to be legal for competition you must have a tube vented from the batt box to the outside of the car and a battery kill switch to the positive side of the battery and alternator. But if it's for just TnT then I think you'll be fine. -Mark
