Electric street and race only EWP? Differences?
Originally Posted by Charles Cyrus
BMR makes this, a drag race alternator mounting kit. My next mod with a race ewp.
http://www.bmrfabrication.com/F-bodyPerformance.htm
I have a 6.0L block so that doesn't fit very well. it doesn't provide any 'tension' either. I am not running a tensioner.
Originally Posted by JL ws-6
That BMR tensioner doesn't fit the 6.0 iron block? I didn't know that there was a differnence
it more or less works, but doesn't fit right.
see the bolt on the left hand side of the bracket on top? there is no place for that to mount on the 6.0L.
I'm not exactly sure which bolt you are referring too.. The bolt seems like it's attached in the above pic, but is that an alum block, not a 6.0?
If that bolt has nowhere to go, is the bracket solid enough to hold the alt. in place?
Originally Posted by 93LS1RX7
I talked to BMR about that, they siad if you wanted to you could tap the block there. I didnt do it, I just made a bracket to get it to work.
do what i did take the idler pulley off the alt. then grind the back of the alt. bracket and bolt the belt tensioner in from the back side where you ground down the bracket. Then installe one bolt in from the back side and let the other side rest on the bracket. Yes you will only have one bolt in it but the tension is always pulling it down becuse of the belt. Have put 3500 miles on it like that no problems and shifting at 6500. All the time.
I have some pics of this set-up in my sig if you would like to see them... Very simple install about 5 min with a grinder and I called it a day..Good luck.
Also I have a race pump and have takin 200 mile cruises at about 3500 rpm and my Temp wont go over 20 under what it used to run at before the race pump. hope that makes sense
so you guys are saying if you have no AC of heat then the race pump will be fine for a race car thats driven about 1-2 days a week for fun?
how would i mount the alternator with a D1SC down there on a 02 z28 with a 408?
Originally Posted by ty_ty13
i looked on mezier's site and it says the HD pump is 40+... there site is a little confusing in the wording...
Additional Notes:
The standard 35 GPM pump is suitable for normally aspirated engines up to 650HP. Supercharged, Turbocharged and high compression, high horsepower applications should use the 55GPM High Flow pump only. For the LS-1 you may need to consider the remote system and block plates to achieve a 55 GPM system
are they considering the HD race pump the 55GPM pump or are they saying get the street pump for TC/SC/ or high CR?
i want to know if they want me to get the street or HD race pump for my 408 procharger motor?
Additional Notes:
Originally Posted by 383ss
no the HD pump is not the street pump. the hd pump is is slightly bigger than the regular race pump and flows 40+gpm. I'm using it in my high compression 408 with no issues at all. they don't really say how much it will support though.
is your 408 street driven?
