Do these tires suck?
Basically, these are not hooking up at all. I even heated them up for a good 10 seconds (line locks), baby launched it from idle (didn't stall it up or make it flash to 4k), and it still would not hook. The car always jumps to the driver's side also. I think it was due to the rear not being lined up right, so I have since then re-centered everything (LCAs and panhard). Even so, these tires just go up in smoke when I try to launch. If I hit it from like a 15 mph roll, it will hook, but I don't really care about "frum roll??" traction
They are Hoosiers, 275/60 15. The sidewall says "Street TD" on them. I've looked through Jeg's, and I cannot find them anywhere...It's almost like they were discontinued? They are also hard as hell. With 15 pounds of air in them, they are still hard to the point where you can't push in the sidewall at all. They are stiffer than my skinnies!
These are the exact tires. I can take pics of them mounted on the wheels if need be. They are on 15x10 Prostars
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
Should I just junk these and buy some M/Ts instead? Those tires are proven, and I'm perfectly fine with them only lasting 5-6k miles
