Drag Racing Tech
drag only guys....e-brake question
Old May 19, 2006 | 11:04 PM
phoenix's Avatar
no e brake here,
Old May 19, 2006 | 11:11 PM
GIZMO's Avatar
Originally Posted by 6-SPD4ME
I heard removing the e-brake will save you up to 5 tenths in the 1/4.
If that upsets you, you will really have a problem with turning the rotors to their minimum to save weight! Every little bit helps.
Be Cool.
Daren
Old May 20, 2006 | 12:33 AM
phoenix's Avatar
dont forget to take the wheel weights off
Old May 20, 2006 | 01:45 AM
revtime's Avatar
I deleted the E brake when I installed the TH400.
I never used it in the 10 years I have owned the car.
and since its an auto..........it went buh bye.
Old May 21, 2006 | 12:53 PM
SiL3NtXWS6's Avatar
mine's gone..and i'm a six speed too
Old May 21, 2006 | 01:45 PM
skipperbisket's Avatar
how do you do it with a six speed? just make sure it's parked level all the time and leave it in gear i'm sure?
Old May 21, 2006 | 02:21 PM
SMOKIN01TA's Avatar
leave it in gear and dont park on any hard inclines, if im street driving i keep a wheel block with me for extra precaution incase it sliped out of gear if im not on flat ground,
and to answer the original question, alot of the as you call it "real" racers have these aftermarket light brakes, i have strange brakes, can use the ebrake with them anyway.
Old May 21, 2006 | 02:43 PM
yeah, i have the aerospace brakes myself, i hadn't even thought about that. guess i should actually install them and i might have found that out. haha, thanks guys.
Old May 21, 2006 | 03:47 PM
bspz28's Avatar
Mine is also out of the car and been out for a while now ..
Old May 21, 2006 | 05:55 PM
slolt1's Avatar
mine is gone and i am a 6 speed for know but soon to be a th-350
Old May 21, 2006 | 06:21 PM
DSG's Avatar
DSG
Mine is also gone...
Old May 25, 2006 | 03:17 PM
  #32
INMY01TA's Avatar
Without the E brake you can run Strange brake calipers, which will clear Weld rims from what I hear.
