Drag Racing Tech
T-tops shattering with slicks?
Old May 25, 2006 | 01:20 PM
Brian2006's Avatar
Default T-tops shattering with slicks?
A friend told me today that with the added traction from slicks, it is very possible and has happened of people's t-tops shattering from the extra traction. Is this true or do I smell bs?
Old May 25, 2006 | 01:35 PM
mike c.'s Avatar
well...i have a 01 ws6 ta(t-tops)and for the last 2-years i cut 1.4 60's motor and 1.3 60's on spray. i pull the front wheels 3-feet or a little more on every luanch. i have nver had a problem and they don't leak in the rain.
my bud in his camaro ss has also never had a problem,1.5 60's motor.
11SECSS's Avatar
I would say bs since I have seen many people go really fast with very low 60 ft times with TTOPS...but then if someone left them unhooked then it might break or come out .
Old May 25, 2006 | 01:40 PM
gator's 99TA's Avatar
its BS.
Old May 25, 2006 | 01:49 PM
chpmnsws6's Avatar
someone was having T-Top envy
Old May 25, 2006 | 01:52 PM
Brian2006's Avatar
that could be very likely to be true since this guy was a hardtop.
Old May 25, 2006 | 02:44 PM
you2slo's Avatar
That would take a lot of frame twisting.
Old May 25, 2006 | 03:28 PM
Bitemark46's Avatar
Might as well throw in the rear window while you're at it. -Mark
Old May 25, 2006 | 05:13 PM
daniel6718's Avatar
what about with no front sway bar? make it any worse...i know and guy that didnt have one and on a 1.5 60' he put a crack in the front window
Old May 25, 2006 | 06:06 PM
Ping King's Avatar
i didnt know a wet hot dog bun could pull a 1.5!
thats some serious flex to cause a front window to crack.
Old May 25, 2006 | 06:19 PM
i hear the floorboards fall off when you hit too much nawz.
Old May 25, 2006 | 06:22 PM
Speed Density's Avatar
hashtagBMW
Iz done it mang, did a 500 shat and blewz my panels right off. IE was a stock motor nothing but nawz, i ran a 8.90 @ 100mph
Old May 25, 2006 | 06:33 PM
davered00ss's Avatar
Moderator
Never heard of that happening.
Old May 25, 2006 | 07:42 PM
ty_ty13's Avatar
7 Second Club
get some sub frame connectors if you are going to dead hook it or the chassis will flex some over time... i dont think it will crack windows.... but anything is possible with enough power and no support :shrug:
Old May 25, 2006 | 08:11 PM
CamTom12's Avatar
the only time I've seen a winshield crack was with a 3-point STB
Old May 25, 2006 | 08:29 PM
s346k's Avatar
my buddy made jokes about me popping a t-top on launch after i got my 4k stall...saying he would laugh when i had to stop and re-insert the t-top. i simply replied with, "if i pop a t-top launching, there's no way i'm stopping..that was a badass launch!"
Old May 25, 2006 | 11:02 PM
daniel6718's Avatar
well i would call bs on it..i kno better than for that to actually happen...but i saw it..since then the guy added a strut tower bar and it seems to leave even...
Old May 25, 2006 | 11:03 PM
daniel6718's Avatar
its impoossible, just like a 3700 pound iroc cutting 1.3 60' with 3.23 10 bolt and m/t d/r...runnin in the nines with a small 200 shot..and daily driven to 15 mpg...
Old May 26, 2006 | 12:06 AM
CAT3's Avatar
Restricted User
Only issue I have seen/heard about T Tops:
1 Leave them unlocked and or loose fitting and watch them leave during high speed, when pressure differences are there like rolling a window down while doing triple digits.
2 Every year we T's have to worry whether the NHRA is going to **** us over by playing with the convertible top rules. And every year someone posts the new rules changed I have to run a full cage to race.....and then later find out its BS.
Old May 26, 2006 | 12:39 AM
1QuickT-A's Avatar
I have seen and heard of windshields cracking and sunroofs/moonroofs busting and/or popping out. But, I have never heard of or seen a ttop crack or shatter due to launching hard on slicks.
