Drag Racing Tech
slick track techique
Old May 30, 2006 | 12:02 PM
dedge's Avatar
Question slick track techique
Whats the best way to take off when its 90+ outside and you just can't get it to hook up. Are some drag strips just to slick in hot weather?I have a 3200-3400 vig convertor,3:73's and 17/35/315 nitto 555r's usually run at 15 lbs? It isn't just me because everyone else is hazing the tire too!
Old May 30, 2006 | 12:36 PM
Bitemark46's Avatar
Yes, once the track surfaces gets really hot it gets greasy. Nothing you can really do except come out at a lower rpm. Or maybe switch to a more agressive DR or maybe even a slick. -Mark
Old May 30, 2006 | 04:04 PM
N20Silverado's Avatar
Loosen front shocks all of the way and take the suspension limiters out.
Old May 30, 2006 | 09:31 PM
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
lower staging rpm is the best cure unless you have a multitude of suspension adjustments you can make to try and tame the surface.
My car was spinning bad last weekend with 1.64-1.72 60 foots off the transbrake on 135 degree track temps.
This past weekend: I footbraked on even hotter 138 degrees and went 1.57-1.58 all night.
Derek
