Drag Racing Tech
sway bar
Old May 30, 2006 | 08:02 PM
ss97dml's Avatar
Default sway bar
pro/cons of taking front sway bar off for racing? is it still drivable on the street or just take it off for racing?
Old May 31, 2006 | 02:12 AM
ninetres's Avatar
Serch this section. Plenty of answers and testimonials
Old May 31, 2006 | 02:14 AM
sdiddy's Avatar
Drove mine on the street for a couple of weeks without the sway bar and had no problems. Just at freeway speeds it felt looser. Don't make any hard maneuvers at high speed and you should be fine. Provides a little bit better weight transfer IMO.
Old May 31, 2006 | 02:25 AM
MountainMotor's Avatar
Here's a few posts about how the front swaybar affects driving https://ls1tech.com/forums/showthrea...=front+swaybar, https://ls1tech.com/forums/showthrea...=front+swaybar. I've had mine off for a while and don't plan on putting it back on.
Old May 31, 2006 | 01:28 PM
NastyNate's Avatar
I took mine off. I really can't even tell a difference, but I don't exactly auto-X the SS to and from the strip. From what I saw it definitely looks like it would hold the frame rails to the lower a-arms and prevent the front end from lifting therefore limiting the transfer of weight to the rear of the car. For a car that doesn't have enough power to lift the weight of the whole front end it has to help with weight transfer.
