4.10s
Looks like that might get you into the 12's. What are you traps?
without seeing you go, i couldnt say if it was your launch or lack of weight transfer... to start with id ditch the swaybar the day before you goto the track.. so you can drive around and get used to it being off, then goto the strip... if you want to buy a mod, try some QA1s...
sorry if it seems off topic, i know you're talking about gears... im just thinking you need to do better with what you have first before you'll see any gains with the gear change... otherwise, when you do what you're doing now with the 4.10s, you're just going to spin harder.
1.9 on drags with your traps isn't impossible. I'm doing that on nittos and in 8000ft DA trapping about 106.
You've got the power, get it to the ground first.
As dude stated, the problem is only going to be compounded with the gears.
What tire pressure are you running?
