Drag Racing Tech
BMR Xtreme Torque Arm
Old Jun 18, 2006 | 12:19 PM
Honda Hunter's Avatar
Exclamation BMR Xtreme Torque Arm
I'm buying a used BMR Xtreme Torque Arm used from a member. I was wondering if this setup must be welded and if it must be welded woul I run into issues re-welding it to my setup? Also if it must be welded is the portion that must be welded also Chrome moly? Is there a special way chrome moly must be welded or is welding it the same as welding any other material?
Old Jun 18, 2006 | 02:19 PM
XpEdItIoUs's Avatar
Yes it dose have to be welded. It comes with a crossmember that welds on your subframe connectors and thats where the nose of the torque arm mounts. As for the special welding for chromoly i don't belive there is a special welding for it but im not sure.
