a4's at the track...
Did you read the entire thread? Burnouts KILL rear rotors and brakes
The SLP traction control module is designed to reverse the TCS/ASR on default to TCS/ASR off so that you don't have to reach down and do it yourself.
And powerbraking an auto to do a burnout is pure hell on the rear rotors. When you press the brake pedal all of the brakes come on then your stomping the gas to overcome the rear brakes. When the burnout is done you could cook your dinner on the rotors.
Get a line lock.
up
The trans am cuts low 1.7s 60ft just about every run on mid 12s
What is your raceweight and rwhp numbers?
David
