Drag Racing Tech
cutting bumpstops
Old Sep 4, 2006 | 09:07 AM
LC's Avatar
LC
Default cutting bumpstops
I was going to cut the bumpstop area where it hits the rear, but upon search i found that a lot of guys just remove all the bumpstop material...
That seems better and you can shave some pounds i guess...
How is that piece holded? spot welded?
Any suggestions on how to remove it?
Old Sep 4, 2006 | 09:58 AM
STOCK1090's Avatar
If you are talking about the bump mount stop directly behind the top of the rear tire you are not going to gain much weight reduction. I just cut them off with a plasma cutter to gain some clearance for the rear slicks. I would not suggest a grinding wheel. It will be an ugly result trying to follow the contour. It will also take all day.
Rich
Old Sep 4, 2006 | 02:38 PM
tektrans's Avatar
I used a 4" wafer wheel and I used a grinding wheel to smooth it out. Came out good. Spray paint it when you're done.
Old Sep 4, 2006 | 03:33 PM
Figz Z28's Avatar
Just go to a welding shop and have them cut off.
Old Sep 4, 2006 | 06:05 PM
LC's Avatar
LC
I can cut them and smooth the cut... but that would leave 3/4 of it still on the car...
I want to try a complete remove... I found some threads but they were old enough to have broken links...
DanZ28's Avatar
Saw Zaw worked great.
Old Sep 5, 2006 | 07:30 AM
tektrans's Avatar
First you cut the bracket that the stop bolts in to. Then if you're using a wafer wheel you hold the wheel perpendicular to the floor and cut out the part the bulges out. I had to cut one side of that bulge then the other and then make a straight cut up top to release it.
I'd post a pic but my wife took the digital camera with her today.
Old Sep 5, 2006 | 01:50 PM
DanZ28's Avatar
I had to do the same thing. Cutting the bump stop itself wasn't good enough. That part that bulges out is some thick steel to. I was gonna use my cut off wheel but the sawzaw worked better, cut through it like butter.
Old Sep 5, 2006 | 01:54 PM
fastGBcamaro's Avatar
Default grinding
Rich
I tried doing it with a grinding wheel because I didnt have access to anything else. It took a damn long time, just like Rich said. Since then I have cleaned them up with a cutting wheel and its much better.
